skellyo
skellyo's Avatar
03.20.2009, 08:54 AM
ok sean i found agood way to prove these will fit. i have a 5s2p 5000 pack here, it uses the same cells. It is 50.5mm thick so the cells are 5mm thick each so a 6s would be 30.5mm thick which will fit.
Wow, those are thin cells. Mike should definitely update his specs on his packs using the 2500mAh cells.
