slimthelineman
slimthelineman's Avatar
03.20.2009, 05:40 PM
your 3200 xps should be fine as long as your running 5-6s with them and not 4s, heck i run some cheapo protek 5s 4000 20/30c packs and theyve been running with that motor for over 6 months now, but the 3d isnt designed to run on 4s, you should use 5s and let the gearing compensate for the tight track not the voltage. we had a guy burn up a 1512 3d at our 1st brushless 1/8th race trying to run it on 4s and gear it up for high 30s....just wasnt working.
yeah 6s on the 3200xp's i think they work great too, temps are around 140 motor, 100 mmm, and 80-90 on batts after a fifteen minute race outdoors. usually geared for 30-32 on 4s for a five minute race. the only 4s pack i have now is a MA 4000 20c. only run it a couple times on 4s and it seemed to work ok, kinda like 19turn for 1/8 scale just curious, do you know what the fellow that fried his 3d on 4s was running for a setup?
