03.21.2009, 02:13 AM
Originally Posted by Sammus View Post
I'm not bias, I want to be convinced otherwise.
AXi 4130/16 Gold:
Can Diameter: 2" (49.8mm)
Length: 2.6" (65.5mm)
Max 8s Lipo = ~30V (Rounding up)
Max Current: 60A/60s
So thats nearly 1800W surge.
Neu 1512 series lists max surge power for all of them at 2000W
They have length 2.4" and diameter 1.53"
Significantly smaller, yet higher surge power.
Even at the AXi's max efficiency constant current (listed as 40A) thats a hair under 1200W, and the 1512's are 1000W constant, and theyre much smaller.
Go to a similar sized Neu, like a 1915: 1.96" diameter, 2.25" long. Still smaller. Constant 1800W, peak 3600W, heaps more grunt, still smaller, and lighter too (14oz vs 14.4oz).
All good info, but you have not considered torque. Torque is what gets stuff moving quickly and more torque can change speeds faster. The 1512 will not make as much torque as the axi. The axi has twice the pole count of the new. Now the 1915 has a higher pole count, so it should make quite a bit of torque.
Also, look at the prices... The 1512 is more expensive than the axi, as it the 1915 (by quite alot). And they are for different applications. Axi makes a great outrunner, and castle will have to step up to excede axi's standards.
We can all agree that neu motors are some of the best in the world, so they should perform well. If I was making anything to race i would go with an inrunner, for both construction and performance. If i was making a crawler I would go with an outrunner. As for a dual purpose vehicle, it all depends on the speed desired...
I have a 6x6 maxx based truck, and I run an axi 2826/10 in it. It is geared for about 20mph in 2nd and 8-10 in 1st. It has tonns of torque and can crawl with the best of them. It will also jump and has plenty of speed for bashing, plus it has exceptional throttle control (due to the multipole design and the great firmware on the MM).
As I said, it all depends. HP (watts) is not the be all and end all of rc. Just read a car mag and you will see that the shootouts are not always won by the big number car...
