sikeston34m
sikeston34m's Avatar
03.21.2009, 10:53 AM
Sikeston 34m has done this with his emaxx. went from a 2826 axi with 22/40 (something like that) gearing to a medusa...
I will say that 99% of people will find an inrunner preferable over an out runner in a land vehicle.
Yes, this is true. There isn't a specific comparison thread about it, ya gotta read between the threads. LOL
Or just ask.
Both setups use 5000mah 20C 4S Lipo
AXI 2826/8 geared 22/40 - Great little setup. I would have to say the MOST efficient setup I have ran. Usually about 10 extra minutes of runtime than an inrunner setup. This motor will run higher gearing, but temps get "uncomfortable".
Medusa 36-60-2000kv geared 52/18 - Another Great setup. Medusa makes the best inrunners I have ever owned.
It would have been easier to compare the two if I were using an older style feigao 2 pole motor. The gap on efficiency and operating temps would have been large.
When Medusa made this line of motors, they did alot of things right. The 4 pole design is truly superior to the old 2 pole motors. I love my Medusa. A little less runtime than the outrunner, but it makes good power. This setup continues to break driveshafts.
On the other hand, the AXI setup would dominate on short track.
Mike's speed calculator shows these two setup like this:
AXI geared for 30.15 mph
Medusa geared for 33.59mph
I GPSed the Medusa setup at 38mph, so these the calculators figures are a little low.
The AXI setup tops out ALOT faster than the Medusa setup. It's quicker "out of the hole". It will yank the front end right at startup, where as the medusa comes into it's real power a little farther off the starting line.
"when sik said "A super low kv inrunner would make ALOT more torque" I thought he mean than an equivalent size/kv outrunner. Now I think I may have misinterpreted his response."
Sorry, I should have said "A super low kv inrunner would make ALOT more torque than it did before." Not to be interpreted that it would make more than the outrunner.
