Updates!
Updates! - 03.21.2009, 08:28 PM
Started working on adapting the muggy bellcrank servo saver steering setup to the lst. It is one of the things that I do not like about the lst, and countless fixes exist for the steering, but none actually address the design's short comings.
I have made decent progress and should have some picture ready material soon. This mod will require a new chassis plate to be made, as I will run a single servo, and it will not reside in the facotry mount holes.
I also plan to extend the chassis length 1.55 inches between the front bulk and the tranny. I arrived at this length as the front center driveshaft can be replaced with a lst1 wheel driveshaft. This will do 2 things, give me more room to mount the battery tray, and the added wheelbase will tame the wheelies a bit. Plus my current setup is slightly nose heavy, moving the lipo an inch back will help that too. And I get to use an off-the-shelf part, and I have about 8 of them.
It is a reasonably simple mod, but does require trimming the side braces and front top brace. This mod can be done with the stock length center driveshafts, but the brake and reverse servos may need to be moved around slightly.
Pics to come soon.
