Semi Pro
Semi Pro's Avatar
03.22.2009, 12:13 AM
Would these be compatible with the Traxxas cvd's? I wonder how big the ball is on the end of the HB cvd?
the ball is 7.92mm
the pin is 3mm in diameter and 13.9mm long.
im pretty sure the hb cups will be to short for the traxxas cvd's
on mikey84's emaxx that we modded in lst2 diffs, we had to make hybrid cvds with mip revo 3.3 bones. since the maxx uses shorter bones than the revo im pretty sure you will need even longer bones on the revo.
some of the old ofna buggys used longer diff cups, i will see if i can find some
