sikeston34m
sikeston34m's Avatar
03.22.2009, 12:26 AM
the ball is 7.92mm
the pin is 3mm in diameter and 13.9mm long.
im pretty sure the hb cups will be to short for the traxxas cvd's
on mikey84's emaxx that we modded in lst2 diffs, we had to make hybrid cvds with mip revo 3.3 bones. since the maxx uses shorter bones than the revo im pretty sure you will need even longer bones on the revo.
some of the old ofna buggys used longer diff cups, i will see if i can find some
So will the Traxxas cvd fit the hole in the cup? How much is the traxxas cvd gonna come up short?
Here is an alternative set of cvd's for the Revo. They have bigger balls.
http://cgi.ebay.com/THS-320-CVD-UNIV...QQcmdZViewItem
Would they work with the HotBodies cups?
I'm having the same problem as Arct1k.
I REALLY want to bullet proof the drivetrain on my E Revo using the RCM diffs I have.
