squeeforever
squeeforever's Avatar
03.22.2009, 11:44 AM
Originally Posted by Candyman2 View Post
im playing with shock oil at the mo, just to get it to a nice setup, might test again today. My rear axles are a bit shot, did I read right that hpi hellfire cvds fit?
If I'm not mistaken, the are a different length. I know some people have gone to the Hellfire suspension setup and that requires the Hellfire axles. Not sure on that though. Best bet is to get the LST CVD bones (~$25 for all 4 I think), LST CVD rebuild kit x2, and I believe Sportworks Mayhem stub axles. That leaves you with 8mm axles all around as well as CVDs all around instead of dog bones in the rear, and allows you to run 17mm hubs. Pretty much any buggy hub will work as long as the cross pin is 2.5mm I believe. CRT is 2.0mm if I remember correctly, so thats one of the few that isn't gonna be ideal (Learned that the hard way).
