stum
03.23.2009, 08:51 PM
I got a reply from Mike today. He has recomended the 70mm so that's what I'm gonna go with. He was running the 60-2000 in his but said that at the end of a 20 minute run he was at the high end of the safe temp zone. I have seen Mike race and as he said he is a very smooth driver and if he was on the edge I don't want to chance it. For helping to control wheelies he has recomended playing with the settings on the controller and my radio, specifically the throttle curve. Hopefully I be placing my order before the end of the week!!!
I'll second that, the 60mm isn't any good for racing.. I toasted one and I'm not a "bad" driver.. you need it geared really low to keep under temp in long mains. Holds up fine for a 3-5minute heat though. I'd say 70mm is the bottom of the scale, but you can snag Castle 2200kv motors for 150 why would you bother with the medusa? PS check the specs, the medusa 80mm will run hotter than the castle-neu, it cannot generate anywhere near as much torque.
