03.24.2009, 12:41 PM
linc, how much tension do you have on the long belt? If you push down with a finger on the top, how much does it "sag"? I'm trying to set mine so tension is good but not too tight to reduce unnecessary drag.
I have tons of sag on that belt. I can easily get it on and off by hand too. Not sure how you set the tension, I guess by altering the height of the front transfer shaft...
I need new belts, but I intend to wear these out first!
