Originally Posted by Takedown
Im willing to spend a good amount to get atleast 2psi from it. If I get a blade with enough angle that will add thrust but intern slow the motors rpms. I think it may be worth a shot atleast. I may double the ducted fans aswell so that the one behind the first one will take all of the moving air from the first ducted fan and shoot it out even faster. 'higher kv motor for the 2nd stage ducted fan motor'.
they already market these things. they are basically viewed as junk, and as metalman said they will not flow enough to create any pressure. if you want cheap thrills, blow 500 bucks on a simple 75hp nitrous setup. a universal zex setup should do. nothing cheaper, even if you fill the bottle fequently. and you do not have to live with the decreased mpg when you do not use it.
