6S vs 4S
alangsam
6S vs 4S - 03.25.2009, 03:30 PM
I recomend sticking with 4s. Maybe gear up a bit if your batteries can handle the increased amp draw. 6s will be incrediblly insane and as far as I'm concerened undriveable.
At first i thought 6S was going to be undriveable but at least in the case of the MMM and 2200 combo use of punch control makes it very drivable. the major benefit are temps, run times and current. I find the temps are 30-40 lower, run times with 5000 batts are at least 10 mins longer (2S 5000 25C vs 3S 5000 25C batts) and of course current draw is 20-40% less.
