Thread: First post....
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.26.2009, 05:58 PM
Originally Posted by Raze ST Truggy View Post
Will I be able to use this in my Raze buggy or truggy?
-Brian
The following quotes are taken from another site..........
"The spur shown and included has 46 teeth. This is the minimum size possible. We are working on a 50t spur as well for some truggy applications. the diff measures about 32.75mm across with 8x16 bearings(outside to outside of the bearings)."
"Id have to measure it to tell you bearing to bearing. But it is the same length as the standard Mugen, AE, Losi, Xray, Caster diff lengths and should drop right into any of them. A shim or 2 in the diff mount to keep it centered will allow it to be used with the brands that have longer diff bearing to bearing lengths"
This may help with working out if it fits into the Raze
I like it.......I LIKE IT ALOT!!!!!!
