Originally Posted by auto2
i used a spacer i got from mike and drilled a 4mm hole in the spacer. very simple and fast.
Did you still have enough room to mount the pinion gear? I have heard the Losi mount is kind of wide and its tight as it is. Have any pics of your setup?
