Thread: Special request
03.28.2009, 01:53 PM
No soldering is required - All you need to do is detach the all of the wires on the 2s adapter from the balancer side block (3 wires) - you just press on the taps in the block and the wires will pull out.
Remove the red white from the the battery end to on the 2s...
Then just push the 2 black wires back into the 3s connector on the balancer side in the correct location to make it look like a 5s adapter...
job done...
