04.02.2009, 11:47 AM
Originally Posted by ambryatim View Post
It has v1.20 V3 MMM. And I think on the gearing I will have to go with 15/68 on an EMAXX. If I remember the 6.5HV is rated at 3400kv.
Sounds about right, the MMM will run the hv motor just fine. I would try your gearing and see how the temps are. As long as you do not try to run heavy/large wheels and tires you should be fine. If your emaxx has alot of al parts, or you run heavy batteries you may have issues, just keep an eye on temps...
