12.13.2005, 07:56 PM
You should have him look at the pack E-Traxxer mentioned. It is cheaper, and can sustain a higher amp draw (not that it would be needed!), and has a higher capacity. The form of this pack wouldn't be too good, but for the price/power/capacity I would get it over the 4000mah one any day.
The ICE is a good charger for Lipo, and does not require a special connector, only the same one that is on the battery.
A balancer would help, as Lipo packs are often destroyed because they go out of balancer. Maxamps can make any pack with any taps that they have. He will also need a LVC device to keep the pack from dropping below 3v/cell.
