MetalMan
MetalMan's Avatar
12.13.2005, 08:25 PM
Originally posted by E-Traxxer
..and a 4200 mah 7.4v pack from maxamps is $77 (with my reseller's account it's $65 :P), and compare it to a side by side 4200 mah 7.2v IB nimh pack, which is $100. Similiar specs, but the Lipoly pack is CHEAPER than the nimh pack :eek:
Or, through my way it's only $59! Or, if the cells were bought loose, and assembled at home, it would be $55!
Not only would it be at this price, but it would also be at half the weight or even less!
Originally posted by squeeforever
yup, parallel doubles amps and capacity while still the voltage still remains the same as where series only doubles the voltage.
The voltage will be higher because there is a greater amp handling capability.
