Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.03.2009, 08:41 AM
I'll try to explain again... Escs like the Mamba max and about every other esc that has a built in bec WILL get lower temps from an external bec. The mmm is different then all the other escs. It has a separate bec built into the bottom of the case. The bec shouldn't produce much heat at all...
