04.03.2009, 12:13 PM
MJ - Yes - mike includes a spacer plate - I line this up against the chassis how you want the tray - Then use a ruler and scribe to put a line where the side kick up is.
I cut off the space at this angle. I tripple check everything and then glue the spacer to the bottom of the tray - Being careful not to glue straps.
Then mount as above making sure that screws go through spacer and tray...
