Joram
Nitro?? BL rulezzz
04.04.2009, 06:36 AM
You don't wanna know how i have tighten the slipper up....
It is almost inpossible how tight it is, with blue loctite on it and that helps...
But the slipper just smokes... Spur becomes hot and i have a lot power so the pads burned away, i saw smoke from the car coming
I'm now using that bycicle repair stuff, what you can cut in you own way!
It is very sturdy and i make it fully covered.
Not only as a normal pad, but also in the middel around the shaft. Just make a round one and cut the hole for the shaft...
I hope you understand this what I say
I am also working on a mountingsystem with no slipperpads, so directly the spur to the shaft...
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
