danhfvcsd
04.04.2009, 11:37 PM
Originally Posted by Finnster View Post
Also, if you want to put lst shocks on, FLM has adapters that work with the kit.
You dont need those adaptors unless you get the flm towers, and they also wont fit the stock towers if anyone is interested to know...
You can mount lst shocks with the stock plastic lst shock mount and washer (although the plastic mount that goes through the 'eye' of the shock needs to be trimmed where the hex nut usually sits) and the long stock savage flux shock tower screw and nut will work fine.
Try and find a thick spacer for some strength for the screw that goes through the bottom of the shock tho - will try and get pictures some day =)
