fastbaja5b
fastbaja5b's Avatar
04.05.2009, 12:45 AM
Rebuild the slipper (replacement spring / washer / nut set is only $7) and replace the pad, tighten it up all the way then reinstall on the car, then hold the pinion and tighten it a tad more using a 7mm ring spanner as that tighten it some more
That has worked fine for me.
Say Less, Do More.
