johnrobholmes
johnrobholmes's Avatar
04.06.2009, 10:17 AM
You won't be able to do a single stage reduction with that motor.
A 14/72 into 14/36 would be about as close as you can get to ideal, although a larger than 36t rear sprocket would be better. The only hitch with using the top hat adapter is that you will need a left side drive freewheel.
---JRH---
