doo540
04.07.2009, 12:15 PM
By next work break I should have a answer for you then. I'm going to switch one diff over to the 6mm outputs and install the extend drive cups and give it a once over. These 6mm outputs from mike are they stronger then the normal traxxas 6mm pins?
