Dubs chops
04.08.2009, 02:07 PM
Originally Posted by azjc View Post
what brand of lipos do you have, it sounds like the same thing that happened with a Maxxamps pack I had
one max amps one zippy h
What do you have the lvc set at? Try setting to 9.0v and see if that helps. Most would prefer a setting between 9.3-9.6v for more safety margin but if you have it set that high on a setup drawing lots of current with poor quality cells you will trip it real early. Even set to 9.0v if you pull the pack as soon as you hit the lvc and check the voltage it will prolly come back up to about 3.4/cell by the time you check it
i have set it at 9v and also to auto detect with the same results each time
Um, is the charger set for some kind of storage charge mode? Seems awfully coincidental that it puts 1/2 the charge back in...
no storage mode is a whole other option screen.
