04.09.2009, 08:48 PM
Need some more help on Motor and battery
Is a 95amp max Feigao 2383 motor ok to use with a 160 amp battery ?
Looking at buying Two 5s 1s1p 3200XP 25c and putting in Parallel = 5S 6400 128 amps.
Or should I get a castle 2200 before I blow the Feigao 7XL ?
The feigao will get hotter than the castle motor. Hot stuff can draw more amps. The castle motor is more efficient, so it will make better use of the available power.
The 160 amp lipo will do fine with either motor. The 6400 5s 25c lipo is good for 160 amps cont, not 128amps.
