Originally Posted by MustGoFaster
Glad you figured out what the issue is.
For others with a Futaba 3PK and a Spektrum module, make sure you reverse the Throttle/Brake setting in the 3PK before attempting to calibrate the radio with the ESC (otherwise it will not sync).
That was it I think. It finally binded but forward was reverse and vice versa. I just switched the settings as you said and I was good. Mine is the FASST module though and RX.
