SpeedAssault
SpeedAssault's Avatar
04.09.2009, 10:50 PM
Originally Posted by spcpicard View Post
a 3200mah pack at 1c would be charged at 3.2 amps, and a 5c could be charged up to 16amps. I don't even know of a charger that will charge at 16amps, but once more packs have higher charge rates, I'm sure new chargers will come out that are capable.
It's rated for 110amps, but most of the run will be alot less, and spikes that are alot more. Weight of your rc and gearing will determine the amp draw and also how hard you pull on the throttle.
yea I was trying to figure what charge rate would be for those 3200's or if the 3200XP's are better and in what advantage ?
I read it was 95 amps.
I'm guessing weight with lipos will be 10 lbs.
the darn Fago motr weight over a lb 13.+ oz.
