Jeremy1976
04.09.2009, 11:46 PM
Originally Posted by Always Dreamin View Post
I wonder if there is anyway to use a starter box for a Savage... Don't think so, only the diff is accessable from the bottom... I will give pull a try. I like the idea of it being simple, so as long as it starts the truck, I am good with it. if not, I will have my OWB replaced, so i can go back to roto if need be.
The key is to properly maintain the OWB. Too many people crank on the starter which heats things up in turn killing the bearing. Quick little bursts with the starter. If an engine is tuned right it should start right up anyways.
