Originally posted by captain harlock
Okay. I'll post the things I need to make an all aluminum truck and you tell me what are the things I need to complete it:
- FLM hybrids( probably UE bulkless, towerless)
- FLM half case for transmission
- FLM shock towers( if I'm not gonna get the ue ones)
- rc- monster heat sink
- RC-Monster idlers
- strobe slipper kit
- G-Maxx single speed conv.
- Super Maxx ext. center drive shafts
- Super duty MSR5 shocks
- Super Maxx servo saver kit
- UE ext. CVDs
- Hex adapters
- extended body
- 7.5 UE diff( 8 spyder)
- Super Maxx ext. suspension kit( with out shock towers)
- FLM extended chassis
Need your help people, please.
Ok, first off, id say you should get 4 UE supershocks, they will be a bit cheaper than 8 msr5 shocks, and will be lighter overall, and perform better, You need tires and rims, i would recomend Crime fighters on 23mm wabash rims, What setup are you gonna be running, as for those chassis, id highly reccomend gorillamaxx chassis , but if your an all out basher, go FLM. Your missing steering blocks, id use the integy steering blocks, there are some other little things you need but that covers some of the bigger things. What motor mount are you gonna use? Stock i assume?
