doo540
04.10.2009, 07:25 PM
Update on the center shafts, if you want to run the Kershaw Steel center shafts, you will need a e-revo rear shaft and a emaxx front shaft. The steel e-revo shaft form KD is about 3 mm to long and the front bulkheads will not go on. I'm also going with the summit plastic shafts to see if they hold up better for me then the e-revo plastic shafts.
