04.11.2009, 07:59 PM
These 6x6 trucks are pretty cool. If someone made one w/all wheel steering.... I know that it would be a challenge but it would be pretty cool.
Pretty easy with this truck. You can install a lst steering setup for the center wheels, as the lst1 chassis is basically mirrored front to rear. As for the rear wheels, I would have to redesign the brace, but it would not be too difficult to do. I would have to use either an 1/8 scale style bellcrank setup, or make a shortened version of the stock chassis to connect the front to the rear. Either way it would not be too difficult. I stuck with fixed wheels as I plan to jump this truck, and the fixed lst2 rear hubs are much stronger.
Originally Posted by its me View Post
Ah! my only plan for the body was to find a large enough cab that might fit most of the wheel width under and then match that by buildin fenders like those on a real semi. Im in the same boat as you cant really find a body that tickles my pickle :)
On a side note do you have a picture of you plastic welder? been wondering what that looks like?
I had contemplated building a cab for the front, but decided that a lexan body may be better as I do plan to beat the truck up...
I would like to do a larger scale semi build... Maybe I will keep a look out for a big body...
I have a smaller 6x6 that I am working on, it use tamiya tlt live axles. I plan to make a flat front semi style cab out of brake tube (mimic the shape of a semi cab at least) and have a full tilt/sliding bed like a flat bead wrecker. That way I can drive my scale crawler truck on it!
