Kcaz25
Kcaz25's Avatar
04.12.2009, 09:34 AM
Can I use the Spektrum DX3.0(comes with 3R3000) with my MMM without the fear of this:
"Depending on the manufacturer of the ESC, there can be issues with the BEC (battery elimination circuitry) not having a high enough voltage output. The issues tend to be isolated with Tekin and LRP ESC’s when used with SR3000 or SR3001 receivers. There are several steps that can be taken to prevent issues from cropping up. First is to make sure you install a power capacitor on the speed control itself, as this seems to prevent high-current drains from causing issues on the ESC’s end. Additionally, installing the SPM1600 Voltage Protector into an open channel on your receiver can further prevent low-voltage issues."
I've heard that it melts stuff! I also though I read that this even happened to Joe Ford!
Any thoughts?
Thanx,
Zack
