RCcarnut
12.16.2005, 07:31 AM
yeah i guess so. I thought it might hurt the older cells or something? I dont know, i'll just try it when i get my brushless.
The thing I would worry about is the new cells. If they don't come fully charged(which most don't) and you add one cell to an 7 cell pack(which is full charged), then peak the new pack. It will charge very fast and the new cell won't get full voltage, then you used them and if you run down the new cell too much you can damage it. At least this is what I thought could happen. Maybe I am wrong:C:
What I do when I add new cells to an old pack is make sure all the cells I put together are full peaked. If I buy new cells I charge them first and the battery they are going on also. The ideal thing would be to just test the voltage on each cell and make sure they are all charged up the same.
Mike has single GP 3300s for sale. They aren't green and yellow in the pic but that doesn't matter much as long as it says GP 3300. You could probably get a 6 pack of the green and yellow off ebay or something.
