Always Dreamin
04.15.2009, 04:18 PM
If you gear for the same speed you will have the same total draw. Personally I would stick to the 4s setup with the cheaper esc. It is just a buggy, not much tire/wheel weight there. Plus you do not really want a big heavy lipo in there, will just upset the balance and cause more draw and heat from the weight.
Plus 4s will be cheaper than 5s, both esc and lipo. I would get a medusa 60mm 2200 motor and a 4s 5000 25c lipo. A decent power supply and charger are a good investment for electric, maybe put some money towards that first.
4s sounds good to me! I already have the Novak black box power supply and triton 2 charger, so I am good there. You sure 2200 kv is high enough? I was looking at the CC neu motor that was 2650.
