04.15.2009, 07:31 PM
Originally Posted by Unsullied_Spy View Post
For the bearings, I think AvidRC carries them (I need them badly for mine) Also check to make sure your turnbuckles are all tight, I had some serious slop in my steering to the point that it wouldn't turn at a dead stop (the servo would just take up the slack).
What's the point in putting a bigger spur in the Muggy? You can easily adjust the gear ratio with pinion gears.
It was what i had at the time, so I put it in. I will say that it is super quiet with the 15/49 combo. I thought it was a plastic spur when I ran it. I can also say that 50k ofna diff fluid is way too light for the center diff. I hope I have something heavier...
