04.16.2009, 02:41 PM
Originally Posted by tonkabilly View Post
The packs are 160mm x 51mm x 46mm. They just fit in without touching the spur. Have maybe 1/2" to spare. The biggest problem is the width. I am now seeing what you said about them being too close to the motor. Once I get the Medusa in that will be the determining factor as to what needs to be done.
Well, you can put them in on their side, so they will be 46mm wide. The medusa is 36mm wide. If you can put the pack in and measure the distance between the center of the spur gear, and the edge of the pack where the motor would touch it. I should be able to calculate what distance you have left, and we will see what gearing you could run.
Also, can you list your motor and tire height again, and if you plan to run the 2 speed and mech brakes, or lock it in either gear? That will help with figuring the correct gear ratios...
I had to do this with my flm chassis and ended up with the 52t spur to get adequate clearance for the lipos.
