12.16.2005, 06:34 PM
I use 5,5mm plugs on my elektronics. On the motor (7xl) I soldered at each wire an female 5,5 plug and heatstrinked it. On the esc (9920) I soldered male connectors at each wire.
On the + and - off each accu I soldered a female connector. I use a sillicone wire with at each side an female connector to connect the two pack to each other. The other + and - off the driving accu I connect the esc wires.
