lutach
lutach's Avatar
04.17.2009, 03:46 PM
I like the looks of the bolido, but do you know where I can get more info on it? Its neat that its a direct fit for an fg pinion which is also mod1.5 and makes life easier
Harold pointed out the place to get the motor and the pinion can be found at https://sdp-si.com/eStore/, click on metric go to spur gears and use the drop down boxes to select the following: 1.5, With Hub & set screw and the bore size.
