04.19.2009, 03:29 AM
Originally Posted by Always Dreamin View Post
That $12 gear you got off E-bay, that is the link right? Seems wierd that with less voltage, I would gear lower? I don't get that. So we are talking $100 before I can even spend $240 on a MMM and $100 on a Lipo!?
The link is for the trans gear. If you plan to run a 2200 motor on 4-5s the stock gearing on the flux will get you between 40-48 mph. You may be able to get hold of the flux parts a bit cheaper if you bid on them. And keep in mind you need the flux motor, not the cc2200 with the ribbed can, as the flux mounts are 39mm diameter and the finned cc2200 is larger... You can get the flux motors off ebay for around 130, and the mmm can be had for 140 if you look around. This is why the rtr flux sells for 600+...
