Originally Posted by What's_nitro?
I think it would have to be aftermarket firmware in the ESC to enable those extra controls. Meaning either the Mfg. did it for them or they have the equipment.
Actually I would like to retract that statement. An ESC cannot modify the kV rating of a BL motor, nor can it modify the input voltage to supply more power to the motor. Heli ESCs have a governor in them that allows the blades to maintain a set RPM. As far as limiting top end RPM in a car you can just use the EPA setting on your radio.
