RBMike
RBMike's Avatar
04.20.2009, 11:21 AM
Originally Posted by Defcon View Post
I too waould like to put one of these on order but I am wondering which motor is correct for my application. I have a Losi 8ight converted to an 8e cirrently using a Medusa mr-036-060-2000v2-5 motor mamba max esc and Thunder Power 4s 50000 14.8v lipo. I am using the losi plastic 45t spur and Robinson 12t pinion. I cannot get this system to start smoothly and want to go with a sensored system. Which motor and gearing combo is recommended. I run mostly on a small backyard track. Thanks.
I ran this set-up last year. It's not the motor, it's the Mamba Max. When I switched over to the MMM the motor worked fine. I'm not saying not to get the Tekin (I'm going to get one too) just letting you know the motor works fine with a better ESC.
