TekinTeamMgr
TekinTeamMgr's Avatar
04.20.2009, 11:42 AM
For most 4s buggy applications I feel the 2050 or the 1900 is ideal. The 2050 is a bit under rated to be honest and is more like a 2200. I run the Losi 2.0 with a direct drive Tekno kit geared with the stock metal spur (48) and run a 16 tooth pinion. I can run over 15 minutes strapped and pull off with 150 motor temps and 4 led's on the speedo for only a few seconds. NO cooling holes in my body either.
The 1900 is butter smooth and can pull the 16 tooth pinion as well. It's great when traction is down and you need to have a very linear powerband.
  Send a message via Yahoo to TekinTeamMgr
