Thread: Traxxas Mutt
Tarill the Mad
04.20.2009, 04:23 PM
Originally Posted by crazyjr View Post
Why not just one? they seem strong enough, and les stress on the EVX. you could turn the transmission around backwards and use a erevo/summit motor mount setup
More power that and it's a test for an idea I have for later. I'd like to keep the mount position over the 3905 tranny to put more of the weight front biased. So turning the tranny around backwards won't help because the problem is the 775 motor hits the tranny before the gears mesh. I figured to start with the stock summit pinion and emaxx spur. Next thing to figure out is running 2 EVXs and what battery setup I can do. I'm not sure I can fit 4 batteries in the chassis. I only have some NiMH batteries right now. Lipos have to come much later.
