switches.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
switches. - 04.22.2009, 06:43 AM
if landing a jump is shutting it off then its a switch position problem, not a switch problem. moving the switch would cure your problem.
I believe the switch should be mounted in the esc case. There are enough things to mount, and enough wires.
I plan on just cutting my switch off and installing a switch from a PC power supply. They are very good quality switches and should do the trick nicely.
SUPERMAXX YOUR LIFE.
