04.23.2009, 01:01 PM
Ok, measured the diff and it is 34mm from the outside of the bearing to outside of the other bearing. That is a hyper8 diff with a plastic kyosho spur, so it should be the widest spur/cup combo you will encounter. Any slack can be taken up with 16mm od shims.
