Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.25.2009, 09:58 PM
Look at other revo setups like yours and see what they are geared. I would go with what BL boy said, get a larger spur.
You need to imagine every tooth you change on a spur as 1 "gear point" and every tooth on a pinion as 2 "gear points". Change the spur because it will change the final drive less.
Also, you probably already know this, but bigger pinion/smaller spur = less acceleration/more top speed. Smaller pinion/bigger spur = more acceleration/less top speed.
