12.19.2005, 06:34 AM
If you really want to add 2 cells, those red GP 3300mAh from Mike should work well.
Just make sure the cells have the same state as your pack when you solder them together (either fully charged or discharged).
I would suggest checking the temps on your pack after you charge and use them. If a single cell get's exceptionally hot, you have a problem.
DAF
