SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
04.29.2009, 10:33 PM
If the MM pro is priced similar to the MM and MMM, I don't see the incentive to buy either the the MM or MMM in 90% of cases when the MM pro has all the capabilities of both (almost the MMM) and more. Correct me if I'm wrong, but the MM has almost the same number of fets as the MMM, thus nearly the same power handling capabilities. The fan and extra surface area of the MMM are what make it handle much more continuous current out of the box, but since the MMpro will have fan that is removeable, you are set for at least any 6s 1/8 scale racing setup.
Area 52 Ranch Raceway
T.R.C.R.
